How do I check if something was tagged in a text field?
Expected result:
Row 1: False
Row 2: True
Could you provide some more details about what it is you’re looking to achieve?
I want to use a formula that will return true or false whether something was tagged in a text field. I want to ensure that I didn’t miss using tags where I should.
What do you mean with tagged in a text field? Are you thinking about checkboxes?
I mean tagged as shown here:
Using the @ function. I kept trying to use Contains or Find or RegexMatch but for some reason ‘@’ doesn’t exist to those. But Substitute can see the @ just fine.
I suggest checking for the actual row IDs instead :slight_smile:
Get Row ID:
thisRow._Merge().ParseJSON("identifier")
Get references in text:
Table77.Filter(thisRow.Text._Merge().ContainsText(CurrentValue.[Row ID]))
Cool! I don’t really get what your formulas do exactly but I was able to get it to work by checking if “Table77.Filter(thisRow.Text._Merge().ContainsText(CurrentValue.[Row ID]))” exists.
Create an additional column to see what values we are working with
thisRow.Text._Merge().ToText()
Looks like this for the first row for example, notice the identifier
  "root": {
    "children": [
        "id": "cl-Qv8dejnaQb",
        "type": "Line",
        "style": "Paragraph",
        "children": [
            "text": ""
            "id": "esv-zbcQc5ag67",
            "type": "InlineStructuredValue",
            "value": {
              "name": "Bravo",
              "type": "ref",
              "objectId": "grid-W3t_CbMG09",
              "identifier": "i-ctzF8rkhgM"
            "children": [
                "text": ""
            "text": " "
        "alignment": "Left",
        "lineLevel": 0
  "type": "slate"
