How do I make a gantt chart usable?
I convert my OKR table to a gantt chart and can’t see the text in the left column at all, nor can I read the text on the colored bars. Can I make it wider and change the colors?
gantt
Dear @Per_Bonomi,
The options for the charts are still limited and like many others, we cross the fingers to get soon a more rich experience.
The size and color options are also limited.
Depending on your use case you might consider to embed Miro
​transpose the chart, i.e. make vertical axis as time axis.
It will make the chart much more compact and readable.
Some examples in my website: Vertical Gantt Chart
