How do I sign up for the newsletter?
Hi, I’m a new member of the Coda community. How do I sign up for the newsletter to receive info on the latest updates?
Hi @Taylor_Lacy,
Welcome to the Coda Community!
You can enable occasional emails from Coda in your account settings by visiting Login - Coda and scrolling to the Email Settings section:
For the forum here, you can click on your avatar, then your name, then Preferences, and you should see Notifications there.
Hi @Ben_Lee, thanks for the reply! I already have the two settings turned on under Email settings:
Regarding your navigational tip, those steps do not work to view product updates. This is the screen I see after following your instructions:
Almost there. Click on “Preferences” in the horizontal menu there, then you’ll see a Notifications option in the vertical menu on the left.
Got it. Thank you, @Ben_Lee!
