This automation is triggered whenever the row is modified, you’d think it would have access to the content of the row. But it seems it does not.
How do I access this value when the automation is triggered?
What you’re looking for in step 2 is
Step 1 Result.
instead of
thisRow.
Edit: oh wait, you have that in your screen shot. When building the automation, it will show as blank, but when the automation actually runs, Step 1 Result.Projected Profit Margin should work.
Ah ok, so it just doesn’t show autocomplete information?
I think autocomplete should work but the preview of the result of your formula doesn’t?
What table does Projected Profit Margin column exist in? DB Time Entries? Or a separate table of jobs, and DB Time Entries’s Job column is a lookup to the Jobs table?
If it’s the latter, you want Step 1 Result.Job.Projected Profit Margin (Step 1 result is a row from the DB Time Entries table)
