How to change font style and alignment in layouts for columns after forms release
I noticed that the layout configuration changed after the release of forms.
It’s great to be able to duplicate layouts now.
Also I like how you implemented the visibility of fields. It’s much easier now.
What I am missing is the possibility to change the display configuration of certain fields (columns)
I don’t find, how I can change the font style and alignment.
In the old version it was possible in the top right corner, as shown in the following image, taken from
But it’s not there anymore:
Is there a way to do that?
Thanks
Jens
Hi Jens!
You should be able to find these formatting settings at the bottom of the right panel that opens when you click to select a layout block.
Note that you need to click on an area of the block that “highlights” it (essentially anywhere but the upper right corner) to see these panel options.
Thank you for your feedback!
Thank you Andrew!
The obvious is the best hiding place :smiley:
Jens.
