Hello, I am using the default template for journaling.
I would like to be able to change this pink colour to a different hexcode colour.
Is this possible?
Thank you!
Is this possible?
Thank you!
Hey @Sleepychomps ,
you can not change the color of the icons for scales. There is just a limited option of icons you can choose from, each coming with its own color preset.
For more color options you can use a slider or a progress bar.
Or you can change the background color of the cell via conditional format.
Best
Daniel
Aw, that’s too bad.
Thank you very much for your answer!
Have a good one!
