Hi Everyone, I’m Meenu Hinduja and my husband Dheeraj Sudan, run a business. I’m running into an issue where the iOS keyboard doesn’t always appear when I need it, and it’s slowing things down quite a bit.
Has anyone else experienced this? If so, how did you manage to fix it or work around it?
I’d really appreciate any suggestions, tips, or settings I should check to make sure the keyboard shows up reliably.
Regards
Meenu Hinduja and Dheeraj Sudan
