It says on Modified() (Coda formulas, formula library, formula cheat sheet - Coda)
A Coda object. This includes tables, views, columns, rows, sections, and docs.
How do I use/get the section object? and is there a folder object?
This is the location when you add a new column you can select the type and at the bottom you will find the property you are looking for
Hopeful I have been putting you in the right direction
Kind regards,
//JP
Thanks.
But I am not finding this context meny. Added a new column and pressed the dropdown for “format as” Am I looking in the wrong place?
Hi,
You get this menu ONLY when you open a new column with the “+”
Of course you can also add a formula to an existing column property to get the same info
The formulas you will be able to find here:
Never noticed the “+” at the right side when making a new table.
Thanks
I`m still in the dark on how to find the Section object?
Maybe i wasn’t clear on my reason for wanting the section object. and it`s modified date.
My objective is to add a changelog to each section; where data about what and when is have changed.
Hi,
With credits to @Krunal_Sheth
To my opinion this post will give you a proper method to keep track on history ![]()
