Hi, We have a template doc that does a sync for a few tables that’s been copied several hundred times. As a result, we’re getting 429 errors on the api calls when the table sync.
Already working and testing on back-off logic for the next release, but would be great to mitigate this in the interim, prior to the next release.
Appreciate any guidance for first steps setting rate limits? Don’t want to shut things down with a bad setting that is too restrictive. Thanks community!
