How to have the months in a language other than English?
I have a calculation date field where the result is presented on this format: January 2019
Until here, everything is OK. The problem is that I need to have the names of the months in Portuguese. I tried to create a text field, with a formula using “Substitute”, but it just doesn’t work.
Does anyone have an ideia of how we can present to the end user the names of the months on their local language?
Thanks.
You could use a Translation Table…
CloudApp
The Date Portuguese column uses this forumla:
Concatenate([Month Translations].Filter(English=thisRow.[Calculated Date].MonthName()).Portuguese," ",[Calculated Date].Year())
Dear @Joao_Jesus,
All the credits to @Ben_Lee :bulb:
The *.gif below explains more in detail the construction how to overcome the language challenge :sparkles:
Bonus; I added the Dutch :netherlands: language, to show how you can prepare a solution that meets more languages.
Enjoy Coda,
Jean Pierre
Hello @Ben_Lee and @Jean_Pierre_Traets
Your help was precious. I’ve already implemented it and it’s working perfectly.
This is also a good solution to eventually translate other similar situations.
Greetings from Portugal,
Joao
Tanks for this formulas @Ben_Lee
