Hi everyone,
I have synced pages in Coda and I want users to print/save them as Letter PDF, but Coda blocks export/printing because they are synced pages.
Is there any workaround to make synced pages printable while still keeping them synced?
Thank you!
hi @Jennifer_Abarquez , welcome to the community and maybe good to know that you are not the only one wrestling with print (to PDF) issues.
I did not test what I propose, but it goes as follows, press CTRL P, select print to pdf (instead of a printer) and then print to the PDF. Second option, I often work in Opera, there you have the native function âsave as PDFâ.
maybe coda can solve the âprint issueâ the way google does it: https://x.com/sundarpichai/status/2049519281600373159
Cheers, Christiaan
@Jennifer_Abarquez
a workaround would be to install a chrome extension that does full page screenshot to pdf.
have tested with pack i.e. Cloud Convert c/o @joost_mineur 's amazing contribution and that doesnt work either.
it needs to be some sort of âscreenshotâ element as coda has disabled print function.
hope this helps!
Cheers!
Mel
