I am trying to modify the default size of the cover photo. I find it too large, since it covers half the page before scrolling down. I would like to set it to 1/4 of the page’s size (as it is shown if the page is viewed on editing mode, with the page settings open.
Does anyone know how to achieve this? I am afraid it looks like the size can’t be modified.
Hello Christiaan! Thanks for the reply. Image() is indeed an excelente function but I can’t find where to insert it at the cover image configuration. The function works like a charm in the body of the document, but I am interested in the image that is presented before all the content. For example:
It worked! Ideally it would be most comfortable to achieve this through a menu option instead of manipulating the original image, but this workaround works just fine! Thank you very much Max!
