Hi guys,
Using the SetControlValue button action on a select list: is there a way to set the value to “Blank”?
IsBlank() is not the solution, since the output of that is always true/false, not a value.
_noop() is not working either.
If I put blank between quotes (“blank”) it will display blank, but it is not the actual blank value. It is a value that just happens to be called blank if you know what I mean. Same as if I would put “whatever” in quotes, it would display “whatever”. I want it to display the greyed out “blank” value that’s always part of a select list.
So long story short: how to reference “blank” ?
