Hello there ![]()
I am trying to find a way to unpublish a form (don’t want to expose it anymore) but cannot find the option to do it.
Did I miss something or is that feature not possible ?
Thank you for your help ![]()
Hello there ![]()
Hey @Maxence_Walbrou! Not exactly, but you can head into the form’s advanced share settings and set it to “no access” so no one can access it, and toggle off “allow submissions” in the form’s privacy settings.
If you don’t need the form at all, you can also just delete that form view (as long as it’s not the core table) .
Hope that helps!
Thank you @Jasmine_B for this workaround.
I deleted the form and created it again to keep it “private”.
Kind regards
