Import from Airtable
I noticed a lot of users bringing over their Airtable bases into Coda docs. Here’s a guide I put together to help in the process:
A lot of users !!!
It’s more easy for migrate if have Import aritable pack , right ?
if (spendTimeForImportFromAirtable > 10 min & users > 1000 ) {
       makeIt = Import from Airtable Pack ;
   //(why)save users time in 5 mins, totaly save 5000 mins at least
The link for this went bad
Hi Henry,
And welcome to the community!
Thank you for flagging the link. I fixed it in the post above. Here is the correct link…
https://coda.io/@john/import-airtable
Thank you for providing this guide, @John_Coda!
I am currently exploring and testing Coda for a client to potentially (hopefully) move from Airtable.
The client uses the properties similar to Created by/on and (Modified by/on) to determine the date each student is registered. I think I have workaround but do you have any suggestions on how to handle this when importing to Coda since I guess that these properties will automatically be set to the time they are imported to Coda and also set to the user who did the import?
For created by/on you can use a date column which defaults to =today() and a people column that defaults to =user(). You don’t have to use a formula to generate that column so importing the raw data will work well. On the modified columns, that’s a little trickier b/c you need a formula to generate that, so there’s no good way to pull that in from Airtable.
Hey @John_Coda is there a way to embed editable Airtable views into Coda?
You can basically embed anything into Coda.
You can also use the Airtable Lite Pack now as well :slight_smile:
Wow that is awesome!!!
