Hey all,
I wonder if you all have experienced this also? Below is the concern I’ve send to Integromat.
It would make my life a lot easier to be able to map everything, but not sure if I can… any workarounds?
For some CODA modules you have the option to:
MAP the fields
for others you don’t have an option to MAP
for some you have the option to MAP, but the mapping doesn’t work.
Should they not all operate in the same way?
Here are some examples below:
1 - You CAN MAP fields & it works
Get a Row
2 - You CANNOT MAP any fields.
Create a Row
3 - You CAN MAP fields BUT it produces an ERROR
Update a Row
NOTE: I’ve tried everything in the DOC field (URL, document ID, etc/.), but I always get the same error.
