Hi all,
since some days I can’t select anymore the yyyy-mm-dd format on the column format.
Or did something changed on the settings I did not see?
Many thanks for your help! ![]()
Thomas
Hi all,
Thomas
Hi @Thomas_Schulz
Yes… Due to the last update of Chrome (Chrome 110), the ISO Date format can’t be rendered when using Coda on Chrome
But the ISO Date format is still available on FireFox and Safari though ![]()
And I know our dear Codans are trying to fix this
Maybe, if you can, you could try to use another browser while waiting for this issue to be solved ?
A small add-on @Thomas_Schulz as I just learned that this has in fact been fixed
and that the fix should be live tomorrow (Feb 16th) around 12:00 PM/1:00 PM PST
Don’t forget to refresh your browser when testing this tomorrow
Thank you so very much Dear Codans
Thanks @Pch for your help! ![]()
