# Issue with Zapier Integration or with Coda API?
**URL:** <https://connect.superhuman.com/t/issue-with-zapier-integration-or-with-coda-api/17679>\
**Created:** [August 10, 2020, 7:47am UTC](https://connect.superhuman.com/t/issue-with-zapier-integration-or-with-coda-api/17679 "2020-08-10T07:47:10Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Mathieu\_Brun-Picard](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/mathieu_brun-picard/32/8858_2.png) [@Mathieu\_Brun-Picard](https://connect.superhuman.com/u/Mathieu_Brun-Picard)\
**Post date:** [August 10, 2020, 7:47am UTC](https://connect.superhuman.com/t/issue-with-zapier-integration-or-with-coda-api/17679/1 "2020-08-10T07:47:10Z")
</div>
Hi 👋
I am currently having trouble with a zap that should trigger everytime a new row is added to a table.
Now my doc is quite large but I didn’t figure it will be an issue for the API.
It appears that on other tables the trigger new row works very well but on this specific table (c. 80 rows), I get the following error
> The app did not respond in-time. It may or may not have completed successfully.
Did anyone ever have this issue and what is the work around this ?
Thanks for your help !
**Author:** ![Paul\_Danyliuk](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/paul_danyliuk/32/27228_2.png) [@Paul\_Danyliuk](https://connect.superhuman.com/u/Paul_Danyliuk)\
**Post date:** [August 10, 2020, 1:23pm UTC](https://connect.superhuman.com/t/issue-with-zapier-integration-or-with-coda-api/17679/2 "2020-08-10T13:23:19Z")
</div>
Hey @Mathieu_Brun-Picard,
Sounds strange that you have problems with some tables but not the others. Usually when doc size is the culprit, it affects all tables in the doc.
Your best bet would be contacting Coda support through Intercom (the (?) button in the bottom right). Once you share your doc with them, they’ll be able to look into the logs, determine what exactly happened, and offer a solution.
