Hi Community
Anyone has a list of keyboard shortcuts? Ex: Create a table, etc
I thought it would be a good idea to document this all in one post.
Thank you
Hi Community
Thank you
Hi @Jay_Lefebvre,
Here’s our help doc for Coda Keyboard Shortcuts:
https://help.coda.io/en/articles/1225832-keyboard-shortcuts
And here are the included shortcuts for Markdown:
https://help.coda.io/en/articles/1821353-using-markdown-in-coda
If you’re in a Coda doc, there is a right side panel flyout that lists the shortcuts if you type…
Mac
Ctrl + /
PC
Ctrl + Shift + /
We need to do a better job of making this more accessible though. The fact that the keyboard shortcuts help requires a keyboard shortcut is not the most helpful way to show this. ![]()
I’ll see if I can bring this up again with the team!
Ben
Thank you! @Ben_Lee
“Cmd - k” to bring up quick search etc. like Notion and others have will be great too?!
Hi @Sumit_Chachra and Welcome to the Community
From memory, ⌘Cmd + k allows you to create hyperlinks from some selected text
sure… when in edit mode. but when it dash etc. why can’t search be done like this?
Ah
I’ll admit I never thought about searching anything within a doc that I’m not currently editing
and even when I do, I’m too used to Chrome Search shortcut to think about using anything else
Maybe you could add your suggestion to the #suggestionbox
