I am just curious. I am still very new to all of this and am working with someone at work using coda.
I want to know if, for example, you create a filter of a table with over 1000 rows in it with 3 different parameters, size, color, shape, etc., would these interactive filters be able to be used to filter such a large table quicker than just a single formatted column? And not slow it down, so to speak?
Dear @Scott_Kauer,
It should not be a problem at all.
The important thing to take care about is the conditions between the filters, I mean:
The combinations of “and” , “or” could cause a conflict as in this sample
Size: “XS” is zero pieces accordingly color and shape will also be zero when you filter only size “XS”.
Just follow your business logic, that you know the best
I used size, color, and shape as an example. We are not using that but thanks.
Interactive Filter, with multi-select enabled, is pretty useless if you have a field with more than a dozen items or so. (as it displays them all, and you must manually select, as you show)
However, you could at least use an interactive filter as a search box for a single item.
- Create a new view and name it something like: “single sku search.”
- Create an interactive filter - but disable “multi-select.”
This will give you a view of your table where you can search for a single item withe your interactive filter.
If you want to search for and select multiple items - run from interactive filter - run!
Hi there! Love this feature. Would it be possible to enable interactive controls on chart views, as with tables? I’m new to Coda so apologies if this is already possible.
Hi there @TSStrickand1 and Welcome to the Community
(and Coda
It is already doable
Here is a very very very quick example
