Launched: More international date and time options
Hi @Jason-Tamulonis and @Ayuba_Audu,
Still very much loving this update, but wanted to report a small issue: When you add a pack sync table to the doc, any Date/Time columns from the sync table do not respect the doc’s date and time format options, and just default the American format.
Hello Jason !
So, what did you decide ?
Can we count on international number formatting in 2025 ? :crossed_fingers:
Yes, I’m working on making it happen.
Thanks for flagging Nad, I am aware of this issue, unfortunately there is a dependency in how documents interfaces with packs and we needed a migration to fix it. We have a fix for this, but it’s blocked on finishing the migration which is taking some time. It is coming though.
Hello @Jason-Tamulonis,
As I am recording a Coda course, I recently had to handle a csv import with numbers, and remembered that for “non american people”, we have to change the locale of our document-to-export before exporting its data to csv (so that numbers can be imported).
Question : Will the international format work with csv import also ? (No more need to import number in american standard :crossed_fingers:)
Thank you :wink:
Great question, @Maxence_Walbrou.
The short answer is yes. The general pattern we try to follow for all value-type conversions is to handle them in a central piece of code shared between UX, formulas, API, and automations. Hence, we get consistent behavior across all of them. Most conversions also have two modes depending on the usage: strict and loose. In strict mode, we have an expected format that must be adhered to, but in many places, we use a loose mode that is more user-friendly. Loose mode often has a preferential order that can depend on various factors like column settings, the document’s regional settings, and, eventually, a user’s regional settings.
The fact that we centralize the handling across all of our systems is one of the reasons deploying these changes can take some time.
Thank you @Jason-Tamulonis !
Can’t wait to have this feature :star_struck:
Do you know when it could be live ?
I am unable to use coda.io, mainly because I use a “non-American” number format. I use the European/Latin American standard. Every time I need to synchronize Excel or Google Sheets, it is a huge difficulty to deal with numbers that are understood as “Text” in the columns. A huge sacrifice and bugs to export to clients. To pull an API that comes in European format sometimes brings a bug. It is discouraging to use Coda in these conditions.
It took a little while for us to slot this into our schedule, but I wanted to close the loop and point out that we just launched international number formats. You can find out more information here: Launched: More international number format options
Actually, the new release doesn’t allow us to import csv with currency (12,05€ isn’t recognized yet).
Have you changed the plan or can we expect this to happen?
Thank you
