Launched: Publish your docs as websites with custom domains
Unfortunately I observe that functions / formulas with User() do not work on custom domains - is there a way around this? It doesn’t grap the user information. I want it to recognize whether a user is logged in or not - in the published URL this works very well, but as soon as it is done via a custom domain it no longer works. If I embed a form via embed, then the user is recognized in the embedded form. Does anyone know a solution?
I am pretty sure this has been discussed in this forum - if I remember correctly the conclusion was that published domains do not have the same functionality as published coda links.
Thank you, @Nina_Ledid for this workaround. I hope they fix this bug soon.
I’ve also created a website on a custom domain bought on Namecheap, and encountering the same issue as the one raised in this thread. My main domain, https://copy-ai-project.org, works well, but I can’t get https://www.copy-ai-project.org to also redirect to it. The Coda help pages state that you need to set up “domain redirects” through our DNS provider, but I couldn’t get it to work.
Namecheap does have a functionality for “URL Redirect”, but this doesn’t seem to work (I think it was primarily intendet to be used when the target is an entirely different domain, not just www → @). I’ve also tried to fix it through a CNAME record, but it doesn’t work either. Any ideas?
It works fine for me - maybe the changes haven’t resolved to your DNS source:
:person_facepalming: Yes, you’re right, it does seem the problem came from my DNS sources. It has been like this for many hours, so I thought they would have updated by now, but apparently not. Anyway, thanks for the help!
I spoke too soon unfortunately. The problem of the “www” subdomain (https://www.copy-ai-project.org) not redirecting to https://copy-ai-project.org seems to persist. Strangely enough, it did work for a short period of time, before it stopped working again.
