Hi there,
I’m using Firefox 73.0.1 on Windows 10, and I have this problem : the box that open when I want to edit a link is blurry (while the rest of Coda is just fine).
Does anyone else have the same issue? Can I solve it myself?
Thanks
Hi there,
Thanks
Dear @Lois_Boutrash,
If this issue is bothering you, you might want to contact the Codans at support@coda.io
Hi @Lois_Boutrash thanks for your report. I have logged a bug for this issue.
I will keep you posted on the same.
Cheers!
Hey @Lois_Boutrash, the fix for this issue has gone live.
