Mobile Card View Toogle/Checkboxes Unresponsive – Web Works, App Requires Opening Card
Hello Coda Community,
I’m encountering a puzzling behavior with since today:
The Card view checkboxes/Toogle on mobile doesnt work properly. So I hope someone can shed light on.
The Issue
  • Inline toggles for my “Yum?” checkbox in Card view no longer respond when tapped.
  • To change the checkbox, I now have to open the card’s detail panel and toggle it there.
  • On desktop (web browser), Card view still allows inline toggles perfectly.
  • Table view on mobile also lets me toggle inline as expected.
What I’ve Tried
  • Reloaded the doc in both the Coda mobile app and mobile browser
  • Logged out/in and even reinstalled the mobile app
  • Confirmed the “Toogle” column is a plain Checkbox/Toogle (no formula)
  • Verified the view isn’t Published or a Synced table
  • Ensured I have full edit permissions (not read-only)
Questions for the Community
  1. Is this a recent mobile UI change? Could Coda have altered Card view behavior to force detail-panel edits?
A few days before, this toogle inline worked fine…
HELP PLS - This Toogle is a key function in my app, clicking into card is not a way forward…
For illustration, here is my Table:
Thanks for the support,
Best,
Ralf
I can confirm this! Something has changed. Hope they will change it as before. It was much more practical.
Hi @Ralfy_Ree and @Arbor_Advice. thanks for flagging this bug. We just deployed a fix, let me know if this is working for you again.
Hey @Evan_Brooks1, thanks for this quick solution. For me, it works like before. I checked on mobile in Card View. Greatings Oliver
Glad to hear it. If you run into anything similar, please feel free to reach out to Coda Support from the question mark in the bottom-right corner of your Coda doc, or by emailing support@coda.io— that’s the fastest way for us to hear about bugs.
Hey @Ralfy_Ree , have you checked also? Does it work for you also? I like the design in your example, nice work :+1: Cheers Oliver
Yes Sir, the bug is fixed. Thanks for the fast adjustments!
