Hello to you expert Coda
I am working on a simple translation model based on translated day and month tables. I wanted to add, using the ISO CODE of the “Machine translation” table, the day, month according to the tables that are translated in the supported languages.
To do this, I started by creating my table and using English and French to see if everything worked correctly.
Then, I started to improve and structure my pages :), so I wanted to create a formula that would allow me to display its information according to this famous ISO code (column “User ISO code”). Yes, I like to take the headache :), but I did not want to use a LookUp() directly.
So I created this formula that makes the relation with the right translated table, but I can’t manage to display only one day and not the whole week hehe.
Here, I hope I’ve been precise enough and I’ll add an embed directly to see all the formulas, etc :).
IF(NOT(ISBLANK(thisRow.[Code Iso utilisateur])),
SWITCH(
thisRow.[Code Iso utilisateur],
"fr", [Traduction des jours].fr,
"es", [Traduction des jours].es,
"en", [Traduction des jours].en,
"de", [Traduction des jours].de,
"zh", [Traduction des jours].zh,
"ru", [Traduction des jours].ru,
"pt", [Traduction des jours].pt,
"it", [Traduction des jours].it,
"ja", [Traduction des jours].ja,
"ar", [Traduction des jours].ar,
"ko", [Traduction des jours].ko,
"nl", [Traduction des jours].nl,
"sv", [Traduction des jours].sv,
"pl", [Traduction des jours].pl,
"tr", [Traduction des jours].tr,
"el", [Traduction des jours].el,
"hi", [Traduction des jours].hi,
"Invalid Input"
"Invalid Input")
