Neet help in a Telegram pack code
It work fine now,
Many thanks @Eric_Koleda
Any plan on adding preview for videos and pdfs file types for coda packs ? (embeding ?)
If you upload a video with the correct content type they it should show in a media player when clicked (after the virus scan has completed). We currently don’t support directly embedding media uploaded this way, as far as I know.
hi @Omar_Mhammedi , would you share your telegram pack with the community? :slight_smile:
Thanks! :slight_smile:
Hi Mario,
I have put the creation of the pack on hold until i learn more javascript.
it work but not as i want it to, i think the last edits i made in the code was an attempt to show a full message in the same column (with all the “reply to” forward to" embeded thumbs… )
i strugled with the dynamic sync table, i still didn’t manage to show the chat names from a list in the pack setting.
It would be nice if we can all contribute something on it and make it public pack code for coda.
PS : Sorry in advance if something is wrong with the code, i don’t remember what’s the last thing i tried. Also you 80% of this code is with the help of ChatGPT … i’m sure it will hurt the fellings of developpers :stuck_out_tongue:
Here is the last code :
pack.setSystemAuthentication({
  type: coda.AuthenticationType.Custom,
  params: [
    { name: "bot_api_key", description: "The API key" },
pack.addNetworkDomain("api.telegram.org");
const TaskSchema = coda.makeObjectSchema({
  properties: {
    message: {
      description: "Message.",
      type: coda.ValueType.String,
      codaType: coda.ValueHintType.Html,
      description: "Message sender.",
    date: {
      description: "Date in Unix format.",
      type: coda.ValueType.Number,
      codaType: coda.ValueHintType.DateTime,
    message_id: {
      description: "The ID of the message.",
    download: {
      description: "files.",
      codaType: coda.ValueHintType.ImageAttachment,
    group: {
      description: "The ID of the task.",
    chatID: {
      description: "The ID of the chat.",
  displayProperty: "message",
  idProperty: "message_id",
  featuredProperties: ["Message", "from", "date",],
async function getFilePath(file_id, context, update) {
  let allowedSize = 4194304;
  let invocationToken = context.invocationToken;
  let keyPlaceholder = "{{bot_api_key-" + invocationToken + "}}";
    method: "GET",
    url: "https://api.telegram.org/bot" + keyPlaceholder + "/getFile?file_id=" + file_id,
  let size = response.body.result.file_size;
  if (size > allowedSize) return;
  let filePath = response.body.result.file_path;
  let fileName;
  if (update.message.document) fileName = update.message.document.file_name;
  else if (update.message.video) fileName = update.message.video.file_name;
  else fileName = 'file.jpg'
  let privateImageUrl = "https://api.telegram.org/file/bot" + keyPlaceholder + "/" + filePath;
  let temporaryImageUrl = await context.temporaryBlobStorage.storeUrl(privateImageUrl, {
    downloadFilename: fileName,
  return temporaryImageUrl;
async function formatItems(update, username, chatTitle, context) {
    if (!update.message) {
      return;
    if (username) {
      if (!update.message.entities) {
        return;
      let entities = update.message.entities;
      let isMention = entities.some(function (entity) {
        return entity.type === "mention" && update.message.text.substring(entity.offset, entity.offset + entity.length) === username;
      if (!isMention) {
        return;
    if (chatTitle && update.message.chat.title !== chatTitle) {
      return;
    let message, download, preview, videoFilename, documentFilename,
      forwardFrom = update.message?.forward_from?.username ?
  `<u><strong>forwarded from:</strong></u> <u>${update.message.forward_from.username}</u><br>` : "",
      replyTo = update.message?.reply_to_message ? `<b><u>reply to:_</u></b> ${(update.message.reply_to_message.text && `<u><i>${update.message.reply_to_message.text}</i></u><br>`)
  || `<img width="100px"src="${await getFilePath((update.message.reply_to_message.photo && update.message.reply_to_message.photo[update.message.reply_to_message.photo.length - 1].file_id) || update.message.reply_to_message.document?.thumb?.file_id || update.message.reply_to_message.video?.thumb?.file_id, context, update) }" alt="Image"><br>`}` : "";
    if (update.message && update.message.photo) {
      let lastIndex = update.message.photo.length - 1;
      download = await getFilePath(update.message.photo[lastIndex].file_id, context, update);
      let previewHtml = `<img src="${download}" alt="Image">`;
      message = `${forwardFrom}${replyTo}${previewHtml}\n${update.message.caption || ''}`;
    } else if (update.message && update.message.video) {
      if (!update.message.video.file_id) return;
      preview = await getFilePath(update.message.video.thumb.file_id, context, update);
      download = await getFilePath(update.message.video.file_id, context, update);
      videoFilename = update.message.video.file_name;
      let previewHtmlThumb = `<img src="${preview}" alt="Image">`;
      let downloadHtml = `<a href="${download}">${videoFilename}</a>`;
      message = `${forwardFrom}${replyTo}${previewHtmlThumb}\n${update.message.caption || ''}\n${downloadHtml}`;
    } else if (update.message && update.message.document) {
      if (!update.message.document.file_id) return;
      preview = await getFilePath(update.message.document.thumb.file_id, context, update);
      download = await getFilePath(update.message.document.file_id, context, update);
      documentFilename = update.message.document.file_name;
      let downloadHtml = `<a href="${download}">${documentFilename}</a>`;
    } else if (update.message && update.message.text) {
      message = `${forwardFrom}${replyTo}${update.message.text}`;
    if (update.message) {
      return {
        message: message,
        from: update.message.from ? update.message.from.first_name : '',
        date: update.message.date ? update.message.date : '',
        group: update.message.chat.title ? update.message.chat.title : '',
        chatID: update.message.chat.id ? update.message.chat.id : '',
        message_id: update.message.message_id ? update.message.message_id : '',
pack.addSyncTable({
  schema: TaskSchema,
  identityName: "MessageTable",
  formula: {
    description: "Sync from telegram",
    parameters: [
      coda.makeParameter({
        description: "The Title of the chat to retrieve messages from",
        optional: true,
        description: "The username to filter messages by",
        optional: true,
    execute: async function ([chatTitle = "", username = ""], context) {
      let url = "https://api.telegram.org/bot" + keyPlaceholder + "/getUpdates";
        method: "GET",
        url: url,
      let results = response.body.result;
      let items = [];
      for (let result of results) {
        let formattedItem = await formatItems(result, username, chatTitle, context);
        if (formattedItem) {
          items.push(formattedItem);
      return {
        result: items,
pack.addFormula({
  description: "list telegram API group chat Id's",
  parameters: [],
  resultType: coda.ValueType.Array,
  items: {
    type: coda.ValueType.Object,
    properties: {
      title: { type: coda.ValueType.String },
      id: { type: coda.ValueType.Number },
  execute: async function ([], context) {
      method: "GET",
      url: url,
    // Create a Set to store seen ids
    const seenIds = new Set();
    // Filter the result array to only include group chats and unique ids
    return response.body.result
      .filter((update) => update.message && update.message.chat && (update.message.chat.type === "supergroup" || update.message.chat.type === "group"))
      .filter((update) => {
        if (!seenIds.has(update.message.chat.id)) {
          seenIds.add(update.message.chat.id);
          return true;
        return false;
      .map((update) => {
        return {
          title: update.message.chat.title,
pack.addFormula({
  description: "Send a reply to a message in a specified chat",
  parameters: [
      description: "Message body.",
      type: coda.ParameterType.Number,
      description: "Unique identifier for the target group chat.",
  resultType: coda.ValueType.Boolean,
  isAction: true,
  execute: async function ([text, chatId], context) {
    let url = `https://api.telegram.org/bot${keyPlaceholder}/sendMessage?chat_id=${chatId}&text=${text}`;
      method: "POST",
      url: url,
      headers: {
        "Content-Type": "application/json",
    return response.body.ok;
@Omar_Mhammedi OMAR WHAT YOU SAID IT’S MIND BLOWING!
Should we make a petition for asking coda to evaluate an integration of this possibilities? :heart_eyes: :heart_eyes: :heart_eyes:
P.s. sadly my competence in the coding field is so limited that i can barely understand what your code does, i cannot immagine being a contributor of it :frowning:
@Mario and @Omar_Mhammedi I just released a first version of a Telegram Bot Pack, it includes an Updates sync table and a SendMessage action.
Will be adding additional features in the future :slight_smile:
Amazing, thank you. would be great if we could reply to a message :stuck_out_tongue:
On the roadmap, will tackle new week and add additional parameters :wink:
You can now reply to a message and I’ve added some additional options as well.
Hey, do you have markup somehow working in the bot?
Neither **bold** nor <b>fdfd</b> not working so far.
@Ivan_Polissky you can use parse_mode to Markdown or HTML and it should work just fine!
