I see that there is a pack for figma, but is there an easy way to integrate graphics and files made in Canva (not canvas!) other than to download the files and then upload them to coda?
Unfortunately Canva does not have at the moment a public API to access data, they are working on it but it is in beta and only works with users on your team:
Thanks. Do you mean my canva team or my coda team? My canva team account is a subset of my coda team, if it matters.
It is about Canva team, basically you can build a tool for yourself but you can’t build a tool to distribute to others.
Thanks!! That makes sense
