Possible to perform an action or check condition after a timeout?
I have an automation that triggers when a row changes. Before it executes an action, it checks if a checkbox is checked in the changed row.
Sometimes, when my team adds a new row, they accidentally check the checkbox, then quickly uncheck it. I don’t want the automation to fire in that case.
I’d like the automation to continue if the checkbox is checked a minute after the row is changed. Is that possible?
Here’s some pseudocode of the desired automation:
  1. When
    This rule is triggered when column isChecked is changed in table Foo. Returns Step 1 Result.
  2. If
    If condition is true, the rule continues to the next step, where
    condition = wait one minute, then check: Step 1 Result.isChecked
  3. Then do something
hi @DSB
what about an approach like below:
the 'if( (strange wording of Coda by the way) could be something like this with an extra condition of the checkbox
does this help or do I miss the point?
Cheers, Christiaan
@DSB,
you can use _Delay( <whatever you want to do> , 60000)
which will delay the execution of the <whatever you want to do> code for 60000 milliseconds, which is 1 minute
max
@Max_OBrien thank you! Exactly what I was looking for.
@DSB, i should point out that _Delay() is an ‘unsupported’ function, not documented in the formula list, and not yet officially released.
but it does work reliably and does not seem to carry any risk (unless you provide a HUGE delay value, i guess).
i have been using it for a while now with no ill effects.
but perhaps the Codans who keep an eye on things here might have other opinions on this.
max
