QR Code Link Switch
Hello dear Codeshians,
I don’t know if it’s possible or if I’m thinking too complicated, but for print documents a link representation as QR type would be great, so that you don’t have to open a table to generate the QR.
Like this:
Thanks for the attention - have a nice one!
Love the simple and intuitive way of implementing it :ok_hand:t4:
Thanks for the great suggestion! In case you haven’t seen it, you can use the Barcode pack to generate QR codes in your doc. You can add a barcode to the canvas with a canvas formula like so:
Hope it helps!
Oh yes! Noah has the dove. Thanks a lot. This closes an important knowledge gap! Perfekt - then i can finally stop creating tables. :laughing:
