I didn’t see it as an option but I could be looking in the wrong place. Is there a way to mass delete multiple sections in a document at one time? I have a lot of sections to go through and clicking 3 times to delete each item is now proving to be quite a task.
Hi @Lynette,
I’m not sure either: I had the same issue but didn’t find a specific solution.
Maybe this workaround works for you, though: if you move all your sections into a folder, then deleting folder will delete all contained sections.
Let me know if this helps.
As Federico pointed out …
Thank you guys so much! That’ll work!
