I support a group in a project management Coda doc. I am thinking about giving each member their own Coda doc, instead of one doc for all members using a bunch of filters. I would make a template doc and then make an instance of it for each member.
My question is about maintenance: if I find a bug in the template and need to fix it, can I fix it just once or would I need to fix it once per instance of the template? Is it possible to achieve re-usability and maintainability in a one-doc-per-user pattern?
