I have make senerio where I use “create a row” coda module, in my coda i have a table with multi select column of “Type” it is a multi select column(Text, Image and Video). I want to send data from make to coda in multi select column with two options (Text and Image), How can I do this?
I’m not sure if Make supports this (if someone else knows).
In the meantime to get you past this hurdle, I would just up a webhook in Coda and send the data via the HTTP module.
ok try this way. thanks
Hey it work now by simply -
writing Text, Image - without any parenthesis and without any brackets.
Thanks
