Hi everyone.
New to Coda but super excited to see the potential
The issue I am dealing with now is as follows:
I have a table with milestones and I want to create a dependency between each milestone to the one before.
Is there a way to link the rows automatically using a formula?
I have found in previous threads that it is necessary to use the Rank formula so that each row receives a specific number and therefore it is possible to reference it, but I can’t seem to complete the action.
Thanks in Advance!
Hi @Ranny_Shor ,
and welcome to Coda Community!
I think that both RowId() and/or Rank() can be tricky as they might lead to inconsistencies; the former due to potential missing values, the latter because of row reordering.
At the same time, I think that if you build up a phases-based process - from a data modelling perspective - you need to have either
- a sequence numbering (for templates)
- a date range (for instances).
At that point, the discriminant in your filter would be one of the two.
In the first, simpler case, your dependency column might look like:
thisTable.Filter([Process Sequence] = thisRow.[Process Sequence]-1).First()
Let me know if this makes sense to you.
Cheers!
Hi Federico, thanks for the quick answer
I didn’t fully understand how I can accomplish what I want without using the Rank formula, and why it might lead to inconsistencies.
I did manage to solve the issue by using the formula you suggested while using the Rank formula in a different column.
Still new to the whole idea of the formulas, I guess I’ll get better with time.
Thanks Again!
Ranny
Hi @Ranny_Shor ,
Feel free to ask anytime.
In the meantime, familiarise with Coda and enjoy!
