Hey all!
I’m trying to make a pack that targets an API that requires me to make a daily bearer token.
I can’t seem to find how to do this in the docs though.
The bearer is returned after I call an API with credentials, but they aren’t OAUTH, just spawned credentials in the app.
Hi @Hartland_Brown - Welcome to the Coda community! The only token exchange protocol that Coda has built in support for is OAuth2, but there is a workaround that I’ve used a number of times that you could try.
- Select an auth type that works for the endpoint that generates the bearer token.
- At the start of every building block’s
executefunction, call a helper function that uses those credentials to fetch a bearer token. (Tip: Set acacheTtlSecson that request so that the resulting token is cached.) - Manually add that token to the outgoing request and suppress the actual auth using
disableAuthentication: true.
If you can point me to the docs for the API you are trying to call I can give you some more concrete advice.
You can see an example of that pattern in my Visualping Pack:
The getToken() function is defined here:
Amazing thank you Eric!
I’ll give this a try!
