I often feel helpless when using Coda I encounter problems with basic things that I can do in 1 second in Excel. Someone will help me to round off the result of this equation? Thank you very much.
It’s the same way as in Excel. In your example you’d use…
round(premium*0.6)
You can also use RoundUp and RoundDown to x decimal places.
It’s weird, it didn’t work when I tried it. Or maybe there’s something wrong with me. I’m trying really hard to get used to Coda syntax and I’m going very slowly. I guess I have to try harder. Anyway, thank you so much.
