# Row color by color picker in each row
**URL:** <https://connect.superhuman.com/t/row-color-by-color-picker-in-each-row/18684>\
**Created:** [October 2, 2020, 11:19am UTC](https://connect.superhuman.com/t/row-color-by-color-picker-in-each-row/18684 "2020-10-02T11:19:14Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Kristijan\_Moser](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/kristijan_moser/32/15796_2.png) [@Kristijan\_Moser](https://connect.superhuman.com/u/Kristijan_Moser)\
**Post date:** [October 2, 2020, 11:19am UTC](https://connect.superhuman.com/t/row-color-by-color-picker-in-each-row/18684/1 "2020-10-02T11:19:14Z")
</div>
I have a Table with my Color Scheme
 ![image](https://global.discourse-cdn.com/coda1/original/3X/9/b/9b86c871d30395bb01b8fc4e856ba756a5e6366d.png)
Diferent tables have a LookUp Column to this “Color Table”, and I can dhoose a Color.
What I would like:
When choosing the color, the row should change to this color.
Is there a way to do this?
It would be more easy, if there were a column type “color picker”.
**Author:** ![Daniel\_Stieber](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/daniel_stieber/32/17045_2.png) [@Daniel\_Stieber](https://connect.superhuman.com/u/Daniel_Stieber)\
**Post date:** [October 3, 2020, 2:19pm UTC](https://connect.superhuman.com/t/row-color-by-color-picker-in-each-row/18684/2 "2020-10-03T14:19:36Z")
</div>
Hey @Kristijan_Moser,
it is not possible to change the color of the row from a predefined hex value.
_In theory_ you can change the color of a row with conditional formatting option, but it is not practicle for your use case, as you can only choose by a range of the predefined colors, not a variable one, and you’d have to set it up for each color on their own.
The only way/formula of using a custom color code automatically right now is in the reactangle shape, but I guess that’s what you already did in the “Visual” column with a circle clipper - which looks cool btw 🙂
**Author:** ![Christiaan\_Huizer](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/christiaan_huizer/32/28269_2.png) [@Christiaan\_Huizer](https://connect.superhuman.com/u/Christiaan_Huizer)\
**Post date:** [October 4, 2020, 10:47am UTC](https://connect.superhuman.com/t/row-color-by-color-picker-in-each-row/18684/3 "2020-10-04T10:47:00Z")
</div>
@Kristijan_Moser,
as @Daniel_Stieber indicated, this is it for the moment. Since I need color logique quite a bit I added something that might help you as well to make the best of it:
 ![image](https://global.discourse-cdn.com/coda1/original/3X/6/f/6f0342fabe764fdcc31e2a083950cb63bd11844a.png)
and the logic I apply is:
`concatenate("https://www.colorhexa.com/",Lower(Slice(thisRow.Hex,2,99))).Hyperlink()`
As such I always have a direct link to more information about the color.
Best, Christiaan
