Selecting values from different tables with inherited visual formatting
Hi there👋
I’d like to suggest an improvement to the visual formatting.
If I connect to a database via relation and select a value, the value can inherit the database formatting.
Since I can’t connect multiple databases to a single column, I use the select method and define the selection criteria in the formula.
However, in this case, the formatting isn’t inherited. Furthermore, there’s no such option in the column editing window, although it is available when using relation.
Assigning custom formatting to such values ​​in the database where they are selected also doesn’t work.
Similarly, even if I use relation, assigning a format also doesn’t work.
This may seem like a small thing to many, but if you work with multiple databases and diverse data, I’d like to highlight them visually and be able to distinguish them by color.
I appreciate the product design and wish there were more features.
Thank you! :wink:
