Hi all, I’m trying to make a Slug Link and I don’t know how to get rid of commas and Polish special characters. I will be grateful for any help. Thanks.
Link: Slug creation
Link: Slug creation
Hey there! Can you explain a little more what you want to do? What exactly do you want to replace the polish characters with?
Thank you for your reply. Below is the list of replacements:
switch ( c)
case 'ą':
return 'a';
case 'ć':
return 'c';
case 'ę':
return 'e';
case 'ł':
return 'l';
case 'ń':
return 'n';
case 'ó':
return 'o';
case 'ś':
return 's';
case 'ż':
case 'ź':
return 'z';
Probably a lot of chained RegexReplace() formulas. That or take you string as input and reinterpret it with a formula like:
thisRow.Name.Split('').FormulaMap(
Switch(CurrentValue,
'ą', 'a',
'ć', 'c',
'ł', 'l',
... the rest of your replacements ...
CurrentValue
).Concatenate().Lower().RegexReplace(" ", "-")
Thank you so much!!!
