# Some columns will not appear on Cards
**URL:** <https://connect.superhuman.com/t/some-columns-will-not-appear-on-cards/49464>\
**Category:** Bugs\
**Created:** [June 19, 2024, 9:40am UTC](https://connect.superhuman.com/t/some-columns-will-not-appear-on-cards/49464 "2024-06-19T09:40:05Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Daniel\_Walmsley](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/daniel_walmsley/32/42674_2.png) [@Daniel\_Walmsley](https://connect.superhuman.com/u/Daniel_Walmsley)\
**Post date:** [June 19, 2024, 9:40am UTC](https://connect.superhuman.com/t/some-columns-will-not-appear-on-cards/49464/1 "2024-06-19T09:40:05Z")
</div>
I think this is a bug, or maybe I am doing something wrong, or maybe it needs to be just a suggestion.
When I create a card view, I understand only the first columns 20 columns are visible.
It seems any columns after the 20th will never appear on the card.
I tried hiding and unhiding, dragging them to the top, and even changing them in the order of the original table. A very thin spacer (1px) seems to appear when I enable one of these columns so something is appearing on the card, just not the content of the column.
 ![image](https://global.discourse-cdn.com/coda1/original/3X/1/8/18db16498817572b581ce8321b7633bc2fb6050e.png)
**Author:** ![anon1959570](https://avatars.discourse-cdn.com/v4/letter/a/eada6e/32.png) [@anon1959570](https://connect.superhuman.com/u/anon1959570)\
**Post date:** [June 19, 2024, 11:54am UTC](https://connect.superhuman.com/t/some-columns-will-not-appear-on-cards/49464/2 "2024-06-19T11:54:17Z")
</div>
If the columns have no content (relations) then you will not see anything on the cards. Try making the name of the columns visible.
**Post date:** [June 20, 2024, 6:43am UTC](https://connect.superhuman.com/t/some-columns-will-not-appear-on-cards/49464/3 "2024-06-20T06:43:38Z")
</div>
Ok, wow. Yep, that was it.
I tried showing column names but even they don’t appear when there is no info, which I think threw me.
Thanks so much
