Some rows are missing the first character in Text fields
That’s all there is to it.
Can you show a picture / example @Morgan?
I notice that it happens only when valueFormat: rich. Will share a public api in the next 5 minutes.
@Johg_Ananda. Ok go to: https://morganatwork.morgs32.now.sh/api/short-opinions?raw&valueFormat=simple
And you will see the “Notes” field looks fine.
Then go to: https://morganatwork.morgs32.now.sh/api/short-opinions?raw
And see that in “rich” format (the default on this endpoint), the response does not have the first character in “Notes”.
Fascinating. Yes I too have experienced this bug when using CrossDoc. Still waiting on Codans to come up with a solution. It is ?reassuring to see it occur in the wild.
New urls.
Rich format: https://www.morganatwork.com/api/short-opinions/i-jSKq1AHXdq?valueFormat=rich
Simple format: https://www.morganatwork.com/api/short-opinions/i-jSKq1AHXdq?valueFormat=simple
I too saw this bug when using Cross-doc and reported through Intercom a while ago.
I suggest you do the same, to add more weight to it.
CC @Ben_Lee (poor Ben, why do I keep tagging you in every Coda bug post)
:joy: I do my best to get everything noted.
Looks like this may have been fixed?
