Hi community. This question is primarily aimed for @Leandro_Zubrezki. Thank you for this wonderful Coda pack. I’m encountering syntax and processing errors when trying to apply a fill or stroke color. And I’ve tried with both versions of the Flowchart styling syntax (older style and newer classDef and class.)
style Element fill:#C0B0FF,stroke:#353535;
For example, the above would cause a error, and not even a syntax error. My diagram renders fine in MermaidJs’ live editor and I copy/pasted it directly into the Coda pack Flowchart formula. I suspect there is a limitation or bug interaction here with parsing the hash character.
I would appreciate any help you could provider. Thank you in advance.
Edit:
I’ve figured it out. It is a bad parsing interaction with the hash character. Perhaps because it’s used as a comment string character. Anyhow, using the URL escape code %23 gets it to work.
