Hey all,
Confirming if others are seeing this issue.
Select Controls with SwitchIf
A convention we use with Coda is having a Select Control specify options, then triggering functionality based on what has been selected.
A benefit of this approach is that the Select Control options can be renamed, but the functionality is preserved across all formula/buttons that use it.
New issue: Switch
We used to be able to do this with the Switch formula as well. Existing formulas still work, but we can no longer add or update Switch formulas to use this convention as of May 21, 2024.
Here’s a Coda doc (edit access enabled, shared with support) where you can replicate the issue for yourself:
Coda Support Response
Coda’s support team has responded that we can use text values instead of an option chip. However, this removes the benefit of being able to rename Select Options without having to edit all formulas that reference it.
My questions are:
- Has anyone else encountered this change in functionality?
- Do you rely on Select options in your Switch formulas or prefer some other approach?
Current solution
Ultimately, we can refactor all our formulas to SwitchIf. However, the buggy behavior that results from the workaround we demo in the doc seems to indicate there is something else going on here.
Thanks,
Brian
