I have 2 columns 1 called level that is a scale from 1 to 6 and the other one is called level name its a select list with 6 names for each of the levels, i need to make that when i change the level on the scale select list column updates automatically. How can i do that?
Great question. You will have to have a relation column set for the Level Name. So in that lookup table you will have next to “Turi dienya, naudojasi dokumentu funkcionalumu” the sliding scale of the dots in the level. Then when you go to the main table and select the dots you will only see the level names that are associated with that dot level.
It’s all going to be relation columns to each other, and make sure you have your filter built into the select list Column options when you go back to the main table.
I hope that helps!
Best,
Dan
