Text styling removed when webhooked to another doc
Hi, I am using webhook to sent data from one doc to another. There are some text fields that have styling in. there are bullet points and line spacing.
When I push this info to another doc the styling is lost. I have also tried changing the fields from normal text fields to canvas fields but the styling is still lost.
is there a way to keep the styling when pushing data using webhooks or is this a limitation of webhook?
yep, this is how webhooks work, the data is flattened in JSON and it gets stripped from all properties like bold and color. cheers, christiaan
It seems there is a solution that keeps the styling here:
But now I need a token for the pack that will work with all docs, since I am copying a template doc and it’s automations. Any ideas how to create an API token for this webhook that will work everywhere?
maybe @Paul_Danyliuk can share his insights, but the general rule is that no formatting is passed on via JSON. Cheers, Christiaan
To create a token that will work everywhere, you go to https://coda.io/account → API Settings → Generate API token without restrictions and with the write or read/write access.
And yes, the solution is to pass over the whole internal state of the formatted text object, i.e. to pass a
Object(
  "text", MyText._Merge()
and on the receiving side I guess you should
[Step 1 Result].ParseJson()._Deref_object("text")
Thankyou @Paul_Danyliuk it works now!
