# Toggle filters inside menu
**URL:** <https://connect.superhuman.com/t/toggle-filters-inside-menu/1609>\
**Category:** Product Feedback\
**Created:** [July 19, 2018, 6:17pm UTC](https://connect.superhuman.com/t/toggle-filters-inside-menu/1609 "2018-07-19T18:17:34Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![Shannon\_Massingill](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/shannon_massingill/32/6846_2.png) [@Shannon\_Massingill](https://connect.superhuman.com/u/Shannon_Massingill)\
**Post date:** [July 19, 2018, 6:17pm UTC](https://connect.superhuman.com/t/toggle-filters-inside-menu/1609/1 "2018-07-19T18:17:34Z")
</div>
I have run into a few times where I want to turn off a filter real quick and change something and then turn the filter back on. I would be great if in the filter menu you could turn filters on and off.
