# Trick: Easier CFL row reference
**URL:** <https://connect.superhuman.com/t/trick-easier-cfl-row-reference/55140>\
**Category:** Tips and Hacks\
**Created:** [April 10, 2025, 8:14am UTC](https://connect.superhuman.com/t/trick-easier-cfl-row-reference/55140 "2025-04-10T08:14:05Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Rickard\_Abraham](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/rickard_abraham/32/35007_2.png) [@Rickard\_Abraham](https://connect.superhuman.com/u/Rickard_Abraham)\
**Post date:** [April 10, 2025, 8:14am UTC](https://connect.superhuman.com/t/trick-easier-cfl-row-reference/55140/1 "2025-04-10T08:14:05Z")
</div>
_For power users_
I found that we can generate the row reference string and copy paste that directly into a formula!
This could prevent tedious row searching with @
```auto
thisRow._ROW_KEY().Split(":").Let(x, Concatenate("@[_tu", x.nth(2), "/_ru", x.Nth(4), "]"))
https://coda.io/embed/MVRa7tcuGD?viewMode=embedplay#_tuCRS/r108&view=full
**Author:** ![hugo\_assuncao](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/hugo_assuncao/32/11469_2.png) [@hugo\_assuncao](https://connect.superhuman.com/u/hugo_assuncao)\
**Post date:** [April 11, 2025, 1:31pm UTC](https://connect.superhuman.com/t/trick-easier-cfl-row-reference/55140/2 "2025-04-11T13:31:14Z")
</div>
Not only this is a nice feature itself but also a nice hidden formula I wasn’t aware!
Thanks for sharing!
