Is it possible to trigger an automation based on closing or opening a Coda section? I think I was able to do this when I used Hypercard back in the day (“on openCard”)… My use case is to reset filters operating on tables when I close/leave (or open) a section in my document. Right now, it looks like automations are only triggered by changes to a table, or by time, but perhaps I’m missing something?
Or is there another way to achieve this?
Thanks,
JB
The closest thing would be having a button at the top that you’d click every time you open a section.
But just out of curiosity, how would you clear the filters?
@Dalmo_Mendonca I have a trick I use for this. I have a hidden checkbox in a column called ‘Display?’. I set a filter on the table for ‘Display = true()’, and then I use buttons to update the ‘Display?’ checkbox based on whatever criteria I have.
It’s a bit slow, but it works.
Joe
How I clear the filters: In addition to the main table, I have an additional one-row, three column table - column 1 provides the instructions, column two is a select field representing the filter for the main table and column 3 is the very ‘reset’ button you recommend.
For example, if the goal of the filter is to view the data by month, the select field in the “control table” is a list of months. The main table filter is set to the value of the select field. The reset button makes the select field “blank”.
But I wish this didn’t need to be manual. As I said, in Hypercard you could trigger an action from an “onOpen” or “onLeave” function.
JB
Hi @Joe_Innes and all -
I’m just wondering how this works for multiple users? Do you run into problems? I’ve been doing similar to what you say here, but I think I need to make an intermediate table that has a row for every user, and then just display whichever row matches the current user. Therefore, different users can be looking at different things at once…
Does that make sense?
