I’m not a big fan of the blinking cursor when it’s next to a large table,
It’s quite distracting and makes the document look like a bit of a bodge, can the cursor height be fixed (eg. 22px)
Dear @Matthew_Osment,
Welcome in the community
To be honest I don’t get the point with the cursor as to my best knowledge it’s depending on the setting on your machine.
Will it be possible to create a *.gif animation to show what you see, so we can advise you better?
Hi @Matthew_Osment,
Thanks for the clear picture.
The “blinking bar” is the input location. Although the options having columns in your page is still limited, hopeful soon we will see this option appearing.
I don’t have a real solution
In the case as in your *.gif when you push “enter” the bigger bar disappears as it moves under the table
Let’s keep the positive mindset and maybe other members have more valuable input.
