Undo for text fields
Definetly a Undo function or something in the Card Popup (when I expand details from a table row). I had a text field I wrote several paragraphs in and due to some odd and random keystrokes I lost all the text. I hit Command Z on keyboard but nothing. Gone forever.
I typed it out in the Expanded textbox view. Then while in the Card Popup I think I hit Enter to start a new line and then Backspace or something like that. Curser was on the very last line. Text gone forever :cry:
Yup, place cursor at very end and hit Enter then Backspace. Gone forever.
https://www.loom.com/share/9e0fdffb76124424816884850d64ced1
Hi there @Robert_Baran :blush: !
Have you check the version history of your doc ? :blush:
You can access it from your doc (the 3 dots menu ...) which appears when hovering the title of your doc.
From there, you should be able to copy a previous version of your doc which might contain if not all the text you typed, at least some of it :blush:.
Good to have learned about revisions. A simple Undo Command would have been faster in this case but I got my data back, that’s all that matters :slight_smile:
Slightly lenghty process to go into revisions > make copy > find what I need and then copy and paste it back > then delete copy of revision :confused:
I’m very glad to know you’ve got everything back in its right place :blush:!
And yep, I agree, the version history tool is not the most practical one :wink: but it can be very very very useful :blush: !
And I also agree with the fact that you should have been able to simply undo what you “did” :wink:. That would have been easier :blush:.
