I have something for problem 2 but I might have overcomplicated the thing
(I got lost somewhere I think
… or I’m simply a bit too tired
I think I’m just not sure why you need to recreate a list using 2 columns when for the updated list of rows the value seem to be the same as the value within Column 1 …
I mean, for the example in the Problem 2 page, Column 1 is already what’s expected in Column 2
But lol, I re-created the list anyway
… It’s just a thought I had
So the first thing I did was to add a column to store the position of the each row in Column 2 and each row in the column Rows to add to column 2 relative to Column 1 (as they are supposed to follow that order) … That new column is called Position Column 2 + Row to add (relative to Column 1) (
Action 1 : “Add” the rows to Column 2
ModifyRows(
thisRow,
thisRow.[Result - Column 2],
ListCombine(
thisRow.[Column 2].Split("/"),
thisRow.[Rows to add to column 2].Split("/")
).WithName(
C,
Sequence(1, C.Count()).ForEach(
C.Nth(thisRow.[Position Column 2 + Row to add (relative to Column 1)].Nth(CurrentValue
).Join("/")
So, I ListCombine() the 2 field to somewhat “merge” and I give to that list the name C using WithName() and then in the expression part of WithName() we have this :
C.Nth(thisRow.[Position Column 2 + Row to add (relative to Column 1)].Nth(CurrentValue)
And what this does is : it first create a Sequence() (i.e.: a list) going from 1 to count of values in C (each value being stored as CurrentValue) and for each value in that sequence it will return the Nth() value in C with the appropriate position relative to Column 1
I’m sorry, I have no idea how to explain this clearly at the moment
But if I take your example and the very first CurrentValue in that ForEach() with the list in Position Column 2 + Row to add (relative to Column 1) being 1,3,2,4
Let’s say CurrentValue = 1 → C.Nth([Position relative to Column 1].Nth(1)) and as [Position relative to Column 1].Nth(1) is 1 the result of that 1st iteration is the first value in C → r1.
For CurrentValue = 2 → C.Nth([Position relative to Column 1].Nth(2)) → [Position relative to Column 1].Nth(2) = 3 → C.Nth(3) → r444
Etc… (Sorry, I really can’t do better right now
As for Action 2, it follows the same principle but for the position this time
ModifyRows(
thisRow,
thisRow.[Result - Column 3],
ListCombine(
thisRow.[Column 3].Split("/"),
thisRow.[Rows to add to column 2].Split("/").ForEach(CurrentValue.RegexReplace("r\d+", "p0"))
).WithName(D,
Sequence(1,D.Count()).ForEach(
D.Nth(thisRow.[Position Column 2 + Row to add (relative to Column 1)].Nth(CurrentValue))
).Join("/")
Once again, this might need some adjustments
… But I hope it helps a little
Edit: As the field Position Column 2 + Row to add (relative to Column 1) uses both Column 2 and Rows to add to column 2 as they are and the list is used in both buttons, this field would need to stay as it it until both rows and positions are fully updated
